Gearbox oil drain plug washer?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Stock265cup, Dec 15, 2018.
  1. On a 265 cup, Is there a rubber washer or something on the gearbox oil drain plug that needs to be replaced if you take it out or can the original be re-used?
  2. 99% of the time it's a copper washer that is recommended to be replaced but can usually be reused fine
  3. Cheers, don’t want to attempt it without knowing I shouldn’t come up against a problem caused by something as simple as a washer.
  4. Change the washer, it’s designed to crush and seal, reusing leaves room for possible leak
