R26 Gearbox oil change
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Pav, Sep 30, 2017.
  1. Pav
    Pav
    Hi guys,
    im after your advice..i own a megged clio and want to drain my box oil..on my clio box there was a plastic cap on the passenger side to put a fresh one in..just had a look today and couldnt find the filler cap on a r26 box..
    can you point me of where its located pls??
  2. Are you after the fill hole or the drain hole ?
  3. Pav
    Pav
    the drain hole on the bottom but not sure where the fill up hole is..some say its on the top of the box under the battery,some that it is on a passenger side..
    thanks
  4. matt e
    theres a plastic wing bolt on the side
  5. matt e
    Mikey4410 and Pav like this.
  6. Pav
    Pav
    thank you very much for your help :smile:
    Mikey4410 likes this.
