Gearbox mount removal
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by mattb03, Apr 11, 2020.
  1. Hi
    I am in the process of fitting Powerflex gearbox mount and am having trouble getting mount out, removed the 3 nuts, soaked WD40 and raised and lowered the jack but the centre stud will not budge.
    Any tips, suggestions be much appreciated.
    Matt
  2. Hammer time.
  3. Put the nut back on until you see a couple of threads above the nut, then a 12 inch extension with the correct socket on the end and then give it a thump with a hammer.
  4. Make sure you have removed the lower mount too, probably need to do the little top one as well.
  5. Cheers for the suggestions, when you say the lower mount is that the dogbone mount?
  6. Yes that's is the one
