225 gearbox mount help needed
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by pervertedmonk, Apr 21, 2015.
  1. Hi.
    im looking at changing the gearbox mount which is the one under the battery.
    Do i need to support the gearbox slightly with a jack when removing, or can this one come out without the need ?
    cheers for your help.
  2. Yeah just put a jack under it to support it
  3. cheers fella.
  4. Changed mine last week , took ten mins ,
    jack under the engine to take the weight, hardest part was getting the bolts undone, as they are tight,
    mine was easier though as I moved the battery to the boot so nothing in the way,
  5. cheers for that :smile:
