Gear linkage stiff & short shift
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Pavandeeplalli, Dec 17, 2014.
  1. This is the answer to you people that dont have the short shift i used to supply...only thing is,this looks rather light to be a ideal swap for the phase 2 linkage.
    Would be interesting to try it out.
    In regards to your problem..its the actuator that the shortshift is attached to causing your symptoms.
    The actuator needs the bush honing out to get things back to normal..
    Do a search,you should be able to find instuctions on how to do this.
  2. I am interested to hear your thoughts on these? They could solve a problem. Perhaps something your machining colleagues could look into :tongueout: It's some pocket money and you have a great reputation.
