Gear change threshold (RS Monitor ONLY)
Discussion in 'Megane Discussion' started by sonyboy, May 2, 2014.
  1. Hi
    I was playing around with it today and was thinking what level I should set it at......i think it defaults at 500rpm......i'm thinking that the revs moves up so fast that you would have red lined before you can react to the beep. Or am I mistaken that the 500rpm beep comes in at maximum power, not the maximum engine speed? (manual says maximum engine speed = red line?). What do you guys set it at and what's the reason? Thanks.
  2. just a quick update after a few more runs.....500rpm actually works, you can still hear the beep and there is sufficient time to change up :smile::smile::smile:
  3. I have mine set at 800rpm just to give that little bit a space when pressing on :smile:
  4. I have mine at 1250rpm to give me plenty of time as I hate hitting limiters, makes me feel like im abusing the car. On a side note does anyone have difficulty hearing the beep? I've driven 200s and the beep is very loud and prominent but on the meg it's barely audible!
  5. -Jamie-
    Yeah the beep isn't that loud, doesn't help that mine is pretty loud with exhaust and induction noise now as well.
    Ps limiter is there for a reasonz mine regularly sees it LOL
  6. Can someone explain what happens when you hit the rev limiter?
  7. Ecu cuts fuel or spark, most stock cars cut fuel, not a good thing really
