Where is the fuse box for the external lights. My near side has gone out again even though its a new hid kit so I'm thinking fuse maybe. Anyway, I remember reading its in a hard to reach location so can someone tell me where the fuse is kept. Thanks.
Your gunna laugh when I tell you. Its in the engine bay, next to the battery. The fuse box is upside down, so battery and tray out.
Well before going for the fuse box I thought I would wiggle all the wires once more and check they were all connected. They worked. So it's not a fuse, which means its probably a loose connection somewhere. Will keep an eye on it but I recon it will be a much bigger problem.
The Hid harness, I had a problem with the harness that connects to the ballast, a leg of the harness was bent and caused short circuit
