FUEL SMELL PROBLEM? Has anyone had the following issue before? Essentially when 1 or both windows are down I get a fuel smell after letting off throttle from a mid to hard pull, basically when boost pressure is released. Generally cruising around or if windows are up there's no smell at all. Only noticed since fitting a new turbo, everything else is more or less the same when i ran a hybrid and I had no fuel smell issues. Carried a smoke test with no leaks, doesnt really help as theres no smell on boost only when releasing boost. Spec Garrett G25-550 turbo Cooksport Manifold Forge BOV (Have tried without this, still smells) Pro Alloy FMIC Nuke Performance Catch Can KTEC 3 inch exhaust and sports cat KTEC intake RS Tuning Map (Smells before and after map)
