Fuel pump part nr
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Filo, Mar 25, 2018.
  1. I'm trying to find a part number of the fuel pump meg 225 .
    220 000 km old and tired pump still works. I do not know how long these pumps last.
    I would replace the complete unit. It's likely that plastic parts would break if I try to replace only the pump.
  2. ianplymouth
  3. Some time ago I had a problem with dirty fuel. I cleaned the whole tank and the pump. The plastic is in a very bad condition. I was afraid to open the lower part. The rubber valve at the bottom of the pump is failing . A one-way valve that needs to keep fuel in the pump housing. Need housing first then its easy .
  4. matt e
    As long as you take your time you shouldn't have any problems and you could get the heat with a hair dryer to make it less brittle
    Second hand ones are quite cheap on eBay
  5. APM
    APM RSM Trader
    Let me know if you want me to pull up pump number for you, just need a chassis or reg number.
