Fuel leak.
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Steven878, Jan 26, 2014.
  1. Hi,
    Over the past couple of weeks iv noticed a wet patch on the drive and also my mpg had gone down a bit, so i had the car on the ramp at work changing the gearbox oil and found my main feed pipe from the tank to fuel rail is badly corroded and leaking!
    Anyone else come across this with their car or have any info on the easiest way to go about changing it, without removing a subframe and heatshields?
    thanks
    steven
  2. The fuel pipe arrived today.
    Big thanks to ads for sorting me out with the part :smile:
    Anyone want to come and fit it for me??? Lol
  3. Gray
    Gray RSM Moderator
    Yeeeeeah..... good luck fitting that.
  4. Haha, who are you going to convince to fit that then?
  5. Convinced myself to do it!
    This pipe is impossible to fit without removing the engine!!! It also wraps round the abs pump!
