250 Fuel Filter
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by -Jamie-, Mar 13, 2015.
  1. -Jamie-
    Where about is it on the MK3 RS?
    Will i expect it to piss fuel all over the place while i change it as well?
  2. If if it's the same as the mk2 its built into the pump/tank element.
  3. It's in the tank iirc
  4. -Jamie-
    Found on another RS forum it's located in the rear passenger arch in front of the wheel, not in the tank like the MK2
    There's it, right in front of the rear axle, passenger side.
  6. -Jamie-
    Cheers Mike!
  7. Noticed this on mine the other week. Did you change yours in the end, jamie?
  8. -Jamie-
    Not got round to it yet Chris, Need to get it done at some point though as i have replaced all my other fuelling/ignition stuff.
