FS. Hybrid turbo
Discussion in 'Car Parts For Sale' started by BG5WRC, Mar 17, 2015.
  1. For sale
    1 x Megane Stage 1 Hybrid turbo.
    This is an upgraded turbo, freshly rebuilt from a second hand td04L turbo in the UK - never installed since rebuilding and making into a hybrid.
    This is a direct replacement for the OEM turbo, you will just need a re-tune.
    Will suite:
    Megane II 225
    Megane II R26
    Megane III 250
    Megane III 265
    Good for 320HP and 380NM with a tune, wind it back a notch and make 300HP safely with less boost on a standard engine.
    Only reason for sale is a change in direction for my build.
    *This turbo is sold without the exhaust housing, simply un-clamp your OEM exhaust housing from your original turbo and use the v-band clamp to install it on this turbo.* I am happy to explain further, it is a very simple process. As mentioned in comments below, the Meg II and Meg III use the exact same exhaust housing so either will fit.
    £550
    Including postage.
    I will be posting this from Australia, will do DHL or express.
  2. It might help the sale if you were to detail what mods were done to make it a hybrid and by whom with what result. A picture also is worth its pixels in gold
  3. -Jamie-
    I would imagine its the same spec that KTR and RST use. Probably has been built by the same people as well
    PS, Add injectors and it should be good for 350/360 on a Mk3 RS if it is indeed the same Hybrid spec
  4. It won't be as iirc rstuning hybrid both sides KTR only do the inlet side
  5. There are multiple " hybrid " specs out there.
    More details are needed. With those power figures , it sounds like a standard 250 meg turbo to me. ( IE a td04 15t )
  6. Wisely said /\
