225 Front wheel hub screws
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by MeggieSVK, Jun 14, 2022.
  1. Hi, does anybody knows the bolt type of the 4 bolts holding the wheel hub to the swivel hub?
  2. Not sure about a 225
    For a RS250 they are
    E14 x 1.75 External Torx Head Screw Bolt Galvanized and Flanged 10.9
    Do you mean number 11?
  4. Like zoto posted. But actually I tought that the steering knuckles are the same for clio 197. Because on the clio there are 4 bolt holding the wheel hub to the knuckle.
  5. Wheel bearing is press fit on the 225. Totally different to 197/250.
  6. If you mean number 11 then they are: 13mm bolts (77 03 002 692) which assure just M10 x 30mm flanged hex head bolts (threaded their entire length) and are 10.9 grade steel (not stainless). Almost £30 from Renault for all 6 of them!!
    Brigsy likes this.
