I will be dropping the subframe soon to do the roll bar bushes. I would like to change the sub frame bushes while its down,and have seen pics with new poly bushes. Who sells them?Doesnt have to be poly. You cant get them from Renualt..i tried yesterday.
If you mean the bushes on the subframe itself, then yes they are available from Renault. The part number is 8200275524. EDIT - That's MK2 btw. EDIT - They are the bushes at the front in this picture: You can see where I tried (and failed) to remove them using a hydraulic puller. You need a press to do it.
Poly bushes here if you wanted to go that route https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/182952066205
