Front Strut Tops
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by ChrisA, Apr 28, 2019.
  1. Evening Chaps
    When running adjustable top mounts what have you done front strut tops too allow camber adjustment easily ?
    thanks
    chris
  2. ianplymouth
    MK2 doesn't need anything doing, mk3 needs the top cutting out to around 75mm
  3. So the 225 shouldn't need any strut top opening to gain access for all the adjustments?
  4. Doesn't need anything doing at all mate.
    Sent from my LYA-L09 using Tapatalk
  5. ianplymouth
    Only required on the mk3
  6. Good news for me then!!
    I just bought a hole saw etc but thought I'd better check before I go crazy, good job too!
  7. ianplymouth
    There quite accessible on the mk2, the mk3 is tucked under the scuttle so a bit more awkward to adjust
