265 Front speakers stopped working
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Hsp, Jul 3, 2021.
  1. Hsp
    Hsp
    Hello,
    The front speakers on my 265 suddenly stopped working. Drove it into the garage yesterday with the speakers on, working like they should be, but when I started the car this morning only the speakers in the back where working.
    Anyone had this before?
  2. You checked the balance/fader?
  3. Hsp
    Hsp
    Yes, that's not the problem. Checked the fuse as well, still good. Weird thing is, if I turn up the volume before starting the car, it works like its supposed to. But if I turn up the volume after starting the car only the speakers in the rear work.
  4. What work did you have done in the garage?
  5. Hsp
    Hsp
    Nothing, just my garage at home were I park my car.
  6. Ok sorry, I misunderstand.
    That's a right pickler then
  7. Id get the unit out and check connections and make sure no of the pins are loose etc.
  8. Hsp
    Hsp
    The radiounit itself you mean?
  9. Yeh.
  10. Was this solved or anyone else had same issue? Have same problem on mine.
  11. 275 NavSport here.
    Been having a similar issue for a while.
    All speakers work fine when starting up. At random times (can be 5 minutes after starting or an hour later) all audio goes dead and unit seems to freeze. When it unfreezes audio volume flashes on the screen at 50% and then only the rear speakers work afterwards until I turn the car off an leave it for a while.
