Front indicator failing
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Cal, Mar 21, 2015.
  1. Cal
    Cal
    Hi all,
    I've read this can be a bit of a common thing on our cars.
    The contacts have been sanded down, but it's still failing intermittently. What's the next step on this?
    I'm kicking myself for not fitting a bulb at the time ... is that where I Would go next?
  2. Cal
    Cal
    Just to update this in case anyone has it in future, the contacts did just require a lot more sanding!
  3. Which contacts are these as mine has the same issue. Is this for the bulb connector?
