225 Front foglights
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by trismotteram, Jul 29, 2014.
  1. Does anybody know if the front foglights on the Ph1 225 are the same units as on the standard Ph1?
    I'm after trying out a set of halos on them to, use as DRLs, but I reckon it would be much easier (and, presumably, cheaper) to find a set from a standard Mk2 Ph1 Megane, than trying to find some straight off a 225.
    :smile:
  2. Rapper
    Rapper Banned
    Actually,i am also suffering from the same issue and can,t find teh solution right know,so if anyone knows about it properly do helps us o fix this problem,if you fix this problem so tell me the right path to fix it.
  3. Yes they are
  4. Sweet, should make them much easier to find. You tack a "sport" name on a used item and suddenly breakers ask for way over the odds.
    I've seen, plenty of times, parts that are the same as the regular model cost twice as much because it was removed from a "sport" of the same car (even to the point they ask for more than the retail price from a dealer).
    Worst is the LCR splitters - peanuts from a Seat dealer but the most I've seen a breaker ask for is £60 plus p&p :/ haha.
