Front badge?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Browno95, Jul 1, 2017.
  1. Does anyone know how to take the front badge of the facelift Megane rs?
  2. Hi Browno, I took mine of few days ago... the badge clips into the base that it's on, the base is bolted into place, think you need special tool to loosen screw. To get it off I managed to slide a thin scraper in between the silver badge and base, once I lifted the silver enough, I managed to see the badge has 4 little prongs / legs, which go click into a plastic piece which is attached to the base, I just wedged a knife between the badge and plastic piece, and then twist a bit until the plastic comes away from the legs. Alternatively you could prob just pry the badge of by lifting away from vehicle, however I'd be worried something breaks. Nb be carefully with your tool against the edge of the badge as it's soft plastic and your tool can make marks in the badge
