Forged Engine parts
Discussion in 'Car Parts For Sale' started by Chris79, Sep 2, 2023.
  1. Selling up the following parts I’ve acquired to build a forged engine, all parts are new, boxed/bagged and either genuine Renault or as stated. Can do a full package or individual parts. I’ll list it as a full package at £3500 but will be willing to split and price accordingly if enough interest.
    Everything there to build a high power mk3 engine. Just needs bolting together. If seriously interested, please message me and I’ll dig it all out the garage and picture everything. Collection required from Fareham, Hampshire for the full kit. If individuals parts, can sort postage.
    Here’s a list of what is included
    new parts
    Wossner Piston kit 82.7mm
    Cat Cam Forged Rods
    Cat cam Valve springs
    ARP rod bolt set
    ACL Big end bearings
    ACL Main bearings
    Supertech valve set, inlet and exhaust
    Head Bolt set
    Thrust washers
    INA Hydraulic lifters (16)
    Full gasket set (head and block)
    Timing belt kit
    De-phaser pulley
    Crank timing pulley
    Crank cover (belt end)
    Oil pump
    Oil spray jets x 4
    Engine sealant
    Pilot bearing
    Oil pump chain and sprocket kit
    Mk3 used/machined engine parts
    Machined block for supplied pistons, (measured, honed and decked)
    Machined head ( pressure tested and skimmed)
    Machined crank (polished)
    Cams (no work carried out)
    Inlet manifold & T/B
    Sump & windage tray
  2.
  3. Hi Chris are these parts still for sale?
  4. Yes mate
  5. Engine’s being pulled on my 275 Cup next week, can you give me your number so I can get back to once I know how much carnage has happened?
  6. How did the carnage happen?
  7. hydroloked driving through about 3 inches of water and a really low ITG intake, at least 2 conrods bent, I’ll be putting a K tech induction on as I mainly use it on road
  8. Fingers crossed the carnage isn't too bad!
