Forge Spring
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Haomaru, Jan 27, 2014.
  1. Hello, i just remap my car to stage 2, i got a forge dv with green spring wich i´m upgrading to yellow one so it´s hits over 15 psi.
    Also i got forge actuator. wich spring i must use on the actuator? this on a 225, car supose to hit over 19-20 psi
  2. Any idea? i beleave the actuator works on a less pressure than the dv, so i must use there green one, but could be yellow?
  3. Hey Haomaru, if your on stage 2 i'd guess that you'd need an uprated spring too, have you emailed forge for advice? As theres plenty on the spring colours for dump valves etc but no so much for the actuator.... Sorry cant be much more help
    Email address is info@forgemotorsport.co.uk
  4. Ok ill email foge.
    Thx
  5. Forge confirm yellow spring on actuator too
  6. That's cool, good to know as i'l be doing this to mine at some point!
    What figures did you make at stage 2? Did you use fastchip for your stage 2 or use a local tuner?
  7. Its is a local tuner, supose to give over 285 hp with 19psis, havent confirm this, need to do some spring changes first
