Forge Recirc Valve
Discussion in 'Car Parts For Sale' started by Ben_r1, Nov 16, 2014.
  1. Genuine Forge motorsport recirculation valve to fit both the 225/230 and 250/265.
    Only used for around 6 months/3000 miles before I swapped it out for a dump valve. Fitted with yellow spring so ideally suited to a stage one mapped car however I can supply a green spring aswell for standard mapped cars.
    Pretty much good as new bar a couple of scratches from fitting/removal.
    £100 posted. If your local I can provide fitting for an additional £30 to save yourself the hassle and it'll take around 30 minutes. Thanks for reading.
  2. Much difference in noise when fitted
  3. PM'd bud
  4. Depends on the application. If it's a 225 then it adds a little more whoosh between gears, even more so with the airbox mod or induction kit.
    On a 250 I'd have to say there's no noticable difference in noise.
    All PMs replied to.
  5. Hello Ben. Do you still have this Recirc Valve?
    Thank You.
  6. Is the 250 recirc valve stronger than the 225 one?
  7. Sold
