forge dump valve springs help
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by chris, Mar 23, 2014.
  1. hi there guys i've got a stage 1 megane 230 with a standard forge blow off valve just wondered if i needed the upgraded spring or not
  2. Actually yeah, I am stage 1, so be nice to know best spring for the DV. Someone hopefully has the answer and its not just down to personal preference.
  3. TimR26
  4. That link helps a lot! Now.. how do you find out how much PSI a car is running?
  5. Green spring will be fine.
    You could upgrade to a yellow one if you feel the need.
    i use blue springs in my car at 1.3bar of boost.
