For those with 250s
Discussion in 'Exterior & Bodywork' started by ryan197, Jul 19, 2019.
  1. Abit of a strange one, just doing some work on the megane, and found two oem holes in the front grill above each blade drl, never noticed them before so assume the covers have been nicked or removed at the garage and not refitted, just been to renault and theres nothing on the system, so just wondering if its the same on others? Or are there covers fitted, any help apprecited.
  2. Pics?
  4. Mine have the same hole on both sides too. Where’s the horn situated? Couidvit be to allow the sound or additional air circulation?
  5. -Jamie-
    They are all like that
  6. Ok then, was just checking as never seen noticed it before
  7. It's holes for front parking sensors
    richmillions and FatRS like this.
  8. Mine has those holes as well, so does all the MK3s I've come across. But... I just ordered a new front grille as I'm retrofitting the 265 DRLs, and mine was a bit knackered - and the new grille doesn't have the holes - just a trace in the plastic marking the outline:
  9. Is the 265 diff to the 250 grille ? Also will the 265 drls work same as 250 or you modifying to be on same time as headlights like 265s do
