For Sale - R26 Forged Engine, Dismantled
Discussion in 'Car Parts For Sale' started by essIII, Feb 22, 2023.
  1. For sale is the dismantled forged engine from my R26. Originally built by RS Tuning in January 2017, the engine has done around 10,000 miles. It was removed this winter for a strip down and refresh, but I've run out of time/patience/money/inclination to finish the job!
    Before strip down we compression tested the engine at ~190psi per cylinder, and in January 2022 she made 315hp and 320lbft on the Engine Dynamics dyno.
    Spec of the engine from the RS Tuning receipt:
    83mm CP Carillo Pistons
    Manley H Beam Rods
    ARP 2000 Bolts
    Supertech Valve & Spring Kit
    Siemens 63lb Flow Matched Injectors
    Genuine RS250 Turbo
    R26.6 SMF and Clutch Kit
    King Race Big End Bearings
    Genuine Oil Pump & Bottom End Set
    Genuine Main & Thrust Bearings
    Bore, Hone, Balancing, Head Rebuild
    All parts/bolts have been removed and stored logically, in labelled bags etc. and as can be seen from the pictures I've started cleaning some bits up. As well as the "headline" forged bits, this is a complete engine so everything from the sump, block, head, standard cams, standard crankshaft, spark plugs, coil packs, alternator, starter motor etc. are included.
    If you're looking to do a forged build, here's an engine already removed and stripped down - just needs a refresh of some of the consumables and then build her back up!
    £2000 takes the lot.
    Any questions give me a shout.
    IMG_20230219_145214.jpg IMG_20230219_154439.jpg IMG_20230219_160056.jpg IMG_20230219_143205.jpg IMG_20230219_144718.jpg IMG_20230219_145457.jpg IMG_20230222_133915.jpg IMG_20230222_133950.jpg IMG_20230222_134045.jpg IMG_20230222_134139.jpg IMG_20230222_134141.jpg IMG_20230222_134743.jpg IMG_20230222_134750.jpg
  2. ... collection from ME20
  3. Sold!
