As the title says, both fogs have stopped working today [they were switched on when the car stopped, then wouldn't come on when I started later]. So I figured the fuse is the likely problem, but can't seem to find a definitive answers as to where the fuse is for the fogs?!?!? There's no clues in the handbook, and surprising enough I can't find any posts which confirm it's one under the bonnet. If anyone has changed it before could they give me a clue please? I have found the guide of how to change fuses under the bonnet, looks simple[ish], but not much point me stripping all that out if the fuse isn't there. The pictures on the glove box fuses are useless. Any clues on fuse rating / location / etc would be much appreciated Thanks
I'd guess it is one in the engine bay tbh sorry can't be much more help. But to make sure id pull the fuses in the glovebox and visually check them to see if they've blown
It's going to be Saturday before I get chance to sort it, but if I still don't have anymore info I'll defo check the glovebox ones first! Thanks
