225 Flywheel probelm
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Shymek, Jul 5, 2014.
  1. I have "small" problem with my flywheel (Helix singlemase + paddle clutch). I need to learn flywheel to work with big torque but I can't.
    I try 2 ways, both on 3rd gear.
    First: from small rev, smooth acceleration to 4000 revs and drop acceleration pedal and breaking by engine to small revs. And few Times like this - gives nothing
    Second: also from small rev on 3rd gear to 3000-3500 revs, drop acceleration pedal and breaking by engine for at least 5-6 seconds and then from small revs acceleration to 2000-2400 revs and also breakin fo 5-6 seconds.
    This way try also for few Times and gives nothing.
    Fault check by CLIP shows: too high torque at the flywheel (or something like that) but another diagnostic tool says: shaft position sensor fault
    Car build on hybrid turbo (but now with standard injectors and boost 0,7-0,9 bar by green spring in FORGE actuator, and yellow in BOV, everything works fine)
    Anyone can help me with this?
    Many thanks
