225 Fault Code Help
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by JamesBryan, Sep 29, 2014.
  1. Got a few fault codes coming up on my brother's 225 that are causing a 'check injection' warning followed by 'esp/asr fault' and revs are limited to 2500rpm.
    We know the car has a slight misfire anyway, as per the fault code for that.
    The main thing is the DF012 - Motorised Throttle in downgraded mode?
    and DF154 Flywheel Signal Sensor Circuit.
  2. I have just had the same issue with my 225 F1 and the car tech cleared the faults because he couldnt be sure what was current and i then drove the car until the check injection showed again - Mine showed as being the Throttle sensor or Body.
    Replacing the sensor first as this is chepest.
    You may also want to follow this process.
  3. Faults were cleared and when you start the car again it comes back and limits the revs to 2500rpm.
