F4R874 re built engine
Discussion in 'Car Parts For Sale' started by Chris79, Jun 15, 2026 at 9:01 PM.
  1. Please see description below. I built this engine for my R26 track car with the intention of getting it back out on track after 3 years off the road but realistically, I prefer my c63 amg purely due to comfort. Will be putting my car back to standard to sell, so this is available.
    Engine has not been timed up yet but the guts of it is done. Will be done before sale upon receipt of sale agreement. I have many pictures of the build but please see attached for reference.
    Thanks, Chris
    Machine shop work
    Block cleaned and honed
    Head stripped, cleaned and tested, skimmed.
    New valve stem seals fitted, valves lapped
    Crank cleaned and polished
    Pistons and rods cleaned and new rings fitted
    Bearing sizes checked and confirmed stock
    Pistons, bearings (thrust, main and big end) and crank assembled and tested.
    King bearings main and big end, ACL thrust bearings, new piston rings, all std sizes.
    Crank removed, pistons left in block.
    All new Bearings removed and cleaned ready for final assembly.
    New genuine Renault rod and cap bolts fitted and torqued to spec
    New Renault oil pump, pump drive chain, crank sprocket and guide fitted.
    Chain cover vapour blasted and painted for protection, new crank seal fitted
    Windage tray cleaned and fitted
    Sump vapour blasted, exterior painted for protection and fitted with new gasket and Reinzosil in Renault specified locations.
    Block de- rusted and coated with 3x coats off VHT Matt black paint.
    Ancillary bracket vapour blasted
    Head installed with new MLS gasket
    Camshafts cleaned and inspected
    Lifters cleaned 4 times until no old oil or deposits present, filled with oil and left for 48hrs and tested for holding pressure.
    Followers/rockers cleaned, inspected and fitted
    Rocker cover and breather plate vapour blasted and fitted with Wellseal sealant
    Inlet manifold vapour blasted and fitted with new gasket
    Throttle body vapour blasted and fitted with new gasket
    New vvt solenoid seal fitted
    Exhaust manifold supplied but not fitted with new gasket, new high tensile studs and copper locking nuts
    Thermostat housing and neck, vapour blasted and fitted with new gasket, new Valeo 89C degree thermostat fitted
    New cam seals both ends
    Cam cover and lifting point bracket vapour blasted.
    Pictures confirm all work carried out.
    Ajusa gasket kits used,head and block
    Elring head bolts
    Renault main and conrod bolts
    King main bearings
    King big end bearings
    ACL Thrust bearings
    Lucas engine lube for all bearings
    Reinzosil for any silicone work
    Wellseal for rocker cover and breather plate
    All vapour blasted parts have been coated with ACF50, left for 24+ hrs and residue removed with microfibre cloth.
    Engine is not timed up yet as will do this upon point of sale, along with rear main seal when off stand.
    Dephaser re-used as not that old, 14k miles, new genuine dephaser bolt and oil seal cap fitted.
    New water pump, idler, tensioner and cam belt (Gates)
    New SNR aux belt and tensioner
    All sensors worked previously and have been re used.
    New set of stock NGK plugs IFR7X8G fitted but not gapped from factory spec.
    Stock injectors and fuel rail supplied but not fitted as recommend they be tested.
    Vvt solenoid will be required as not present.
    Air con pump and alternator will be fitted with new belt kit.
    Any questions, please ask
    £2400
