R26 Expansion tank
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Paul ja, Sep 28, 2020.
  1. Looking at replacing the expansion tank
    Is it best to go genuine Renault or are the ones from ECP good quality ?
  2. Decided to go with genuine Renault
  3. Anything I need to know before I tackle changing the expansion tank - any advice or tips gratefully received
  4. matt e
    iirc the engine mount needs to come off to get it out
  5. Ouch
  6. Is this a case of support the engine / remove bolts / remove mount ?
    Any idea what the torque settings are for the bolts ?
    Wonder if the ktec engine mount fitted means there is more space to get the bottle out without removing the mount ?
  7. Might be more room as the top of the Ktec mount is smaller than a stock one so maybe.
    If not yes it’s just a case of getting a jack under the engine to support it then remove the mount.
  8. matt e
    62nm for the mount to body
    105nm for the mount to the bracket
  9. Many thanks
