Hi, I bought this exhaust ( https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/332390772263 ) for my r26 but it’s still fairly quite, is there anything I can do to make it a bit more louder. Don’t want to decat it tho and was thinking of maybe a sports cat but there so expensive.
Chances are dude that its almost definatley a chambered box and not straight through as is often desired for performance applications. The only thing to do is change back box for a straight through one dude.as always research goes a long way.
Dependant on your local exhaust fabricator it will be a few quid i can tell you that. I would personally sell that system and go for the k-tec full 3" system.Its going to be future tune friendly ie ........flow enough exhaust gases for all your future mods should you wish and its perfect noise wise.not to loud not to quiet and most importantly it IS straight through. Its a work of art fabrication wise also
I know this is a stupid question but do you reckon I could just get the back box from that Ktec system and fit it on to my milltek system?
you can get this fits straight on the existing milltek pipes. ive swapped my milltek back box for this one you can buy the back box on its own http://www.k-tecracing.com/show_product.asp?id=2674&appid=12
When i bought my 225 it had a Miltec exhaust, did a few track days and the noise level was between 86-90db, i went to fit a decat pipe and found that the exhaust was straight through, not one box at all, removed the cat and fitted the decat and it went to 119db, so as you can see the cat quietens the exhaust a lot
