Exhaust size
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by James and his 250, Sep 1, 2014.
  1. Hi guys, what size is the exhaust on a 250
    2.25 or 2.5??
  2. 2.5 iirc mate. Outer diameter.
  3. 2.5 on the Megane 250 as well Mike?
  4. Yeah it's the same exhaust as the 265
  5. Just take it to a custom exhaust garage will cost you around £30-80 all in.
  6. So a bolt on exhaust is not recomended?
  7. Any exhaust garage can make and fit that piece of pipe, they will weld the bak part on as joining it with a clamp may cause leakage as the joint is going against the flow. Just let an exhaust place make it up for you
  8. I agree, less hassle aswel.
  9. Ok thanks guys will do that, so i don't even need to buy a meter length of stainless steel pipe then? Ill try get this sorted this weekend then :smile: Thanks
  10. Any custom exhaust will have the pipe and flare equipment to make that pipe. The place i took mine to flared both ends, clamps the front end and welded the back joint.
  11. Just bought http://www.ebay.co.uk/itm/2-5-inch-64mm-Stainless-Steel-Exhaust-Tube-Pipe-1m-MIJ-/320487828562, got a customer at work sorting it for £40, very good welder, long life wanted £80.
    Im not getting any pops from the exhaust while driving at the moment, only hear them if stationary in sports mode. Seems the standard exhaust is supposed to pop a bit so its a little strange, but with the size of the back box I'm not surprised!! Not seen anything like it!! Is this the OEM box?
  12. 1. You need the exhaust really hot then it'll pop like mad
    2. In the warmer weather its harder to do, in winter itll pop loads more
    3. Yes thats std backbox
  13. Fair enough Matt! My MR2 exhaust was louder when hot and I must have taken the Megane to that limit, and its not really popping, maybe I'm going deaf though, that exhaust was too loud :eek:
    Thanks for all the replies
  14. Dont get me wrong the exhaust isnt loud, backbox chop will do wonders loved it on my old r26. On the 265 throughout the winter months it popped like mad, got warm and stopped popping. I found i had to go out and exhaust the exhaust really hot before it started popping again, better at night when its cooler!
  15. So how you going to fit that pipe with no flared ends?
  16. Went for a drive last night, did get some pops! Completely random ones very unpredictable
    Got a welder doing it Ryan, they can flare them themselves. I even asked him if he wanted flared ends and he said no.
