Hi im after the little bracket at the bottom of the cat/de cat that holds it to the block. when i got someone to put the standard exhaust back on they never re fitted it and now the bolts keep coming loose at the turbo and stinks the cabin out, its for a r26 too thanks.
Think I’ve got one in the garage with a bolt snapped in it, can have that for postage if you want to drill it out?
Ill have to have another look tomorrow but im sure it uses the bottom bolt on the cat/flexi pipe joint then another bolt that goes into the block.
