I have no idea if this is even a part? My car seems to flash up ' Check ESP' every few weeks - generally when giving it a bit of lick. So I assume there might be some sensors in the front that need replacing. Are there? Anyone got some part numbers to throw at me?
Mine chucked up this error, when it was plugged into clip it showed the front two abs sensors at fault.
Check sensor wirings first.Bearings are SNR XGB 41166 S01 or Renault Master front wheel bearing are same.
Got a garage to replace then mate, the abs sensors were £44 each from Renault. Best to get it plugged into clip to see what the error is at you may only need one.
Thanks. Got a bluetooth OBD2 reader on the way, hoping torque pro will shed some light. Good to be able to brace myself for a price though.
