Esp/asr system fault, no traction control or abs
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Trophy451, May 29, 2017.
  1. Hi, when I start up the car the above lights go out then come on pretty much right away. Once I start driving they then go off until I hit around 25-30 mph and then come back on again and any braking before this kicks the brake pedal back like an abs sensor fault.
    Has anyone had similar issues as the car is out of mot at the moment and can't get it to a specialist with clip.. .....unless someone in Fife has a good diagnostic tool they could try for me.
    The brake fluid and all discs and pads have been changes recently but the fault remained.
    Could the and pump or an abs sensor send up this fault? Traction control disables with abs.
    Any help appreciated thanks.
    Sent from my SM-G930F using Tapatalk
  2. Faulty abs sensor was doing this to me. Double check brake fluid level too
    Trophy451 likes this.
  3. Thanks mate that's ideal I'll start with the rears as I had a seized caliper and wheel bearing away on same side so there's a fair chance of damage.
    Where is the best place to buy the sensors ? Are they the same on any other renault model? Just so I don't have to the pay r.s tax.
  4. I bought it from renaultpartsdirect, not sure if its the same as non rs. Let us know if u figure it out
  5. That's great buddy cheers. I'll order a couple in through my mate and see what we can come up with.
    rTEM likes this.
  6. I had this too - heard a metal clang (like a brake disc dust shield coming off) and then this came on a couple of time since and goes off.
  7. Cracked abs ring?
