Hi, today i heard that my cars fans are running on hi rew and the i had the "Check injecton" error. I went 100 meter to the shop then opened the hood and there was cold air comming from under the engine. The hose from the inercoller came of? I had this whhooshing sound when i accelerated before but i thought that this is the turbo. After shopping, i wanted to start the car but it doesn't start (But no errors). Is this normal when the hose is off? Thanks for help.
As above will start and run albeit slowly with boost hose off. It sounds like a fuse, power orearth wire has failed if fan is on.
Thanks for the answers. The car started yesterday , but after a while the "check injecton system" error comes again and the coolers running like crazy. Now the car is at the car mechanic, will update what was the problem.
The cooler fluid temperature sensor was bad. Everything is working fine after replacement. Thank again for the help guys!
