R26 Engine running hot?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Nunez20, Nov 18, 2016.
  1. Hi all,
    noticed this morning when I got to work I had steam coming off the bonnet (it was raining and wet), I drove 25 miles to work and not hard at all. Is something running hot or is this normal? I have noticed it a few times but never took much notice.
    Regards
  2. Should be normal in area immidiatly above turbo, that being hottest.
    Your temp gauge should indicate if thermostats starting to stick or you're low on coolant.
