Engine Removal Megane 225 F1
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Jukidam, Dec 28, 2019.
  1. ianplymouth
    perhaps i could go out and run mine in :cry::cry:
  2. At first I think, shit I never could drive that much before dyno day, but now I think I will have 2k made in a month :tearsofjoy:
    But I mean kilometers so 1k are 600miles
    Thanks for the tip with the lug, will watch about that, I put it just in and was happy :tearsofjoy:
    You still waiting for a map or :grimacing:
  3. ianplymouth
    Needs checking that its located properly as i think it can weep fuel if the tank is filled to the brim.
    Yes we are still in lock down, as soon as he opens i'm booking and driving 280miles each way
  4. Till now no smell, but I will see the problem hopefully at this weekend.
    That's a long way =0 but It will be worth :tongueclosed: I also have mine at 9.May at dekkermotorsport together with a friend which drive a hybrid mk3
  5. ianplymouth
    I would have gone to him with mine, but here's to far for me.
    Sure he will do a great job for you
    Jukidam likes this.
  6. Yes i heard from a lot people he's very good.
    Thanks for the tip!
  7. ianplymouth
    Say hi from me please :laughing:
    Jukidam likes this.
  8. I will do :grin:
    ianplymouth likes this.
  9. Hey guys,
    Do anyone know if the shift "cables" are adjustable like VW ant others?
    I just clicked them back as I put the engine in
    The shifters isn't that nice as it should.
  10. ianplymouth
    No adjustment at all, they just click in, whats the problem is it stiff (not centring) is it side to side or forward and back ???
  11. I don´t know in 225 Megs, but in 250, in the cabin side, have adjustment only in side to side link. Maybe I´m wrong but remember seen like threads in the end of link.
  12. It have play (swinging left and right) but see a video on YouTube how I could fix that maybe that also could fix my little issue here
    Everything goes without pressure in and out but its not really smooth.
    And that only before it's warm. So if it's complete cold it's a little bit hard to put the first gear in after 10 km just not smooth and after 30 km everything goes very good. Gearbox is 40.000 miles old
    Could also be only because the oil
    I filled in kroon 75w90. Maybe I will go back to Renault elf or something. Need to change the driveshaft anyway
    I thought there is something for adjustment =p
  13. ianplymouth
    Is that oil fully synthetic oil ????
    have you just replaced the oil as well ???
    if you have just changed the oil it will take a bit to get the feel back
  14. Oh I see I maybe buy the wrong one it's 75w80
    Gl4+ so I have no issue with the brass inside.
    There is written mineral oil.
    I buy it with the knowing I would change it anyway soon and it's more for flushing =p
    What would be your recommendation for the ND0?
  15. ianplymouth
    All the Megane gearbox's mk2 and mk3 use a fully synthetic oil, the mineral oil is a lot thicker than the fully synthetic stuff.
    It needs to say fully Synthetic on the bottle
    If you want to flush it, then buy cheap fully synthetic
    i can't remember what i have used, will get the can tomorrow and have a look
    Jukidam likes this.
  16. Oh okay good to know.
    As I filled the gearbox I was thinking my self it's thinner as I thought but okay maybe because it was 25 degrees :tearsofjoy:
    I just need to found out if all driveshafts are same for the mk2 phases than I could order new driveshafts.
  17. ianplymouth
    What is the body code for your car, Chassis number
    Don't need all of it just the first half
    Jukidam likes this.
  18. VF1CM0M0635.........
    Thanks for your help!
  19. ianplymouth
    Okay just checked and it looks like the 225 and R26 drive shafts are all the same, the only one that's different is the Diesel Sport Mk2 (it has a mk3 gearbox)
    Long shaft, right hand side number is 8200278603
    Short shaft, left hand side number is 8200278602
    Just google or Check Ebay for cross reference
    Jukidam likes this.
  20. Thank you a lot for the research!! I will check it and buy them
  21. ianplymouth
    Jukidam likes this.
  22. Awesome, thanks!
  23. ianplymouth
    This is the oil i use
    49860307113_a764381954_k.jpg Gearbox oil by Ian Austin, on Flickr
    Jukidam likes this.
  24. Thank you! If I find it in Germany I will order the same
  25. ianplymouth
    If you can't, just make sure the specification's are the same
    Jukidam likes this.
  26. Okay need to go this way, doesn't found it.
