250 Engine remap
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Crombe76, Mar 21, 2014.
  1. Hi, what is the best remap for the RS250 from owners experience rather than the marketing blurb. Have seen suoerchips and seems easy enough to do but I guess that is a standard map that isn't tweaked in anyway shape or form to the car.
    I also wouldn't mind seeing a before and after for posterity.
    Seen places like RS Tuning and K-Tec, K- Tec being much closer as I'm near Reading Berkshire.
    Any thought and experiences would be much appreciated , cheers
  2. You'll get mixed opinions mate but I think most will favour RS tuning. Get good gains too but I'm sure someone with a 250 would be better to say
  3. I can only vouch from my own experience so here is my 2 cents:
    http://fastchip.nl/ - for a remote DIY map
    http://www.rstuning.co.uk/ - for a live map on a RR.
    And the before (fastchip) map VS the live map (rstuning). As you can see they are similar.
    It is worth mentioning that RSTuning also do remote maps, but having not tried it I cannot comment.
  4. Which one of these is the rs tuning map, red or green?
  5. Looks to me like red is the before map and green the RST map.
  6. ^ What he said. Red was the remote DIY fastchip map, Green was the live RSTuning map. The reason for the drop in power was because the remote map was knocking slightly at top end.
  7. Hi, knocking? What is that I'm new to all this.
  8. Read up on knocking and I guess that a remap with a specialist can iron out such problems where as a remote version may not eliminate such a serious engine damaging problem
  9. Hi mate, i had my RS250 mapped at RS Tuning, the difference is night and day, torque everywhere, turns a really great car into a bit of a weapon. It's a long way (4 1/2 hrs each way for me) but well worth it. I took my .R up there as well, Paul really knows how to get the best out of Renaults.
  10. I read that RS tuning can play with the VVT to spool the turbo up quicker which the remote maps can't do
  11. Any idea how much in terms of cost ?
  12. there is a group buy on one of the forums for RS Tuning remaps.
  13. RSTuning live map you are looking at £380 in a group buy after VAT or there-abouts. The fastchip remote map cost me £400 after VAT and shipping.
    Obviously the live map then adds another £70 on top for a tank of fuel traveling there and back :tongueout:
  14. If that's the one which ran alongside 197.net it's unfortunately full :worried:
  15. You can get launch control turned on aswell at rs tuning if that's of any interest
  16. -Jamie-
    Im going down to RST in the next couple of months, Stage 2 map with Launch control, Which will never get used anyway LOL
  17. Anyone used KTec in Dorset?
  18. Dont ...
  19. Uh O, that bad?
  20. Launch Control wow sounds awesome
  21. Worse.
  22. Dont really fancy an 8 hour round trip if I can help it, any thoughts on superchips remote bluefin, failing that I'm ringing RS tmrw for a day out
  23. Unless someone is able to provide a before/after of a Superchips/Bluefin similar to my Fastchip graph I can't see why you would chose them?
  24. I was hoping someone may have had some experience with them as you say so I could weigh up all the options fella
  25. No worries. I'm sure someone here will have a graph, I think theres been a couple that have done what I did and then had their DIY map overwritten with an RSTuning one.
  26. Fastchip looks great, but was a little concerned by the knocking aspect and I'd guess I'd never know of any issues until the engine went bang, errors came up or I got it dyno'd. It seems basically RS Tuning as they can iron out any issues there and then. Just a pain re the distance and also I can't pop it back to standard if need be.
  27. I'll give RS a buzz tmrw as only off next week so if they've a slot I'll go for a day trip to sunny Leeds. Rather have it done properly
  28. Is the correct answer :smile:
  29. Well if you are worried about engine issues then id also avoid the Superchips/Bluefin, speak to Paul when you are at RSTuning about them :wink:
  30. Pauls other half is expecting this week so only today on offer for a remap which I can't do so it'll have to be in the summer when I've got some holiday time. Bummer
  31. The jury is still very much out on the bluefin lean issue...
  32. -Jamie-
    I would like to see some conclusive proof that it is a lean map in the form of some graphs and not just some tuners hearsay to drum up more business
  33. Did he give you the A/R ratio print out with that too?
  34. I plan to get an AFR check on a dyno in the coming weeks :smile:
  35. No mate. What you see is all I have I'm afraid.
