Engine oil rs250
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Wmrs250, May 21, 2014.
  1. Tried a search but keep getting errors, can anyone recommend a good oil for my 250, has anyone ever tried 5w40 castrol edge fs or millers xf 5w40 fs
  2. I use Fuchs Titan S but a quality cheaper alternative would be Shell Helix Ultra.
  3. Ive just put Millers Nanodrive in my 250
    http://www.millersoils.co.uk/nanodrive.asp
    I spoke with Opie Oils for advice and if your car is still under warranty, then you should use a Renault 'RN0710' approved oil.
    http://www.opieoils.co.uk/c-898-rn0710-oil.aspx
    If I wanted the very best for it, I was recommended to go with a 5w-40 ester based oil
    http://www.opieoils.co.uk/c-656-5w-40.aspx Out of those, the ester ones are Fuchs Titan Pro s, Millers Nanodrive CFS NT, Moyul 300V and Gulf Competition.
    As mine is out of warranty, I decided to go with the Millers Nanodrive, a bit more expensive, but some excellent reviews of it if you do a search
  4. Thanks for the info, big help
  5. Is it 5W40 or 5W30 for 250?
  6. 5-40
  7. What about Halfords fully syntetic oil? I went today to Halfords and only one engine oil 5w40 which comply with RN710 is their own brand.
  8. Probably be fine but I wouldn't for track work. Euro car Parts do Shell helix very cheap which is also Renault approved.
  9. I bought the shell helix for £37 delivered from ebay
  10. 6 litres in total
  11. I wanna have it in boot to top up if required. I need to top up now about 0,2 litre. I have seen Castrol Edge Diesel 5W30 with RN 710/700, but guy in the shop said it is only for turbo diesel engines.
  12. Finally I topped up 0,4 litre today. Car is nearly 5k miles/ 4 months after service. Do you think it is all right?
  13. That's fine, mine has used 3/4 of a litre and it's done 6k miles.
    I just use the Standard Renault elf evolution oil, the stuff recommended/supplied by Renault. Can't go wrong with that, it clearly works well for the type of engine.
  14. Thank you. I was bit worried about oil consumption, as I never experienced this before.
  15. Most performance engines us a little oil it's pretty normal. My Clio 200 did it aswel.
