250 Engine oil leak
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by PahLok, Dec 24, 2020.
  1. PXL_20201224_145007314.jpg PXL_20201224_145016245.jpg PXL_20201224_145014217.jpg PXL_20201224_145009863.jpg PXL_20201224_145012017.jpg
  2. ianplymouth
    Its going to be that first piece of pipe from the engine to the hard plastic "T" piece, just replace with another piece of pipe.
    The other oil dampness on the rocker cover is from the bolts that hold the cover down, if you remove one at a time, clean and then apply a smear of gasket maker or sealer and tighten the back down, sure it 8 ftlb or 12nm
    PahLok and Beau like this.
  3. Cheers! Much appreciated
  4. as Ian says both classic upper seal weeping, the one by coil probably cam sensor seal, remove the 10mm bolt and slowly (while twisting) pull complete sensor out and renew seal
    PahLok likes this.
