225 Engine mounts ???
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by ianplymouth, Jul 24, 2015.
  1. ianplymouth
    Hi all
    I have fitted the new gearbox insert without much problem, a little bit of washing up liquid in the two holes and slid in a treat.
    The upper mount insert wouldn't go in at all, the mount was really knackered, so a new one was purchased and fitted no problem.
    Tried to find where the lower engine mount is and found this, what the fudge is it for ???
    Mozart75 likes this.
  2. No sure on the first? Do recognise it but got brain freeze!
    Second is the upper left hand side and it bolts to the bulk head.
    The third is the lower engine mount and what your after
    And four a megane!!!
    Edit sorry the picture did not show up when I first looked....sorry!
    You sorted for the lower mount now mate?
  3. ianplymouth
    Also i have 2 dog bone mounts one at the top rear of the engine and one at the bottom, is that all i have ???, i can't see where my inserts go (PFF60-820) I presume i don't need them
  4. ianplymouth
    Hi Boardy
    no i am not sure about the lower mount, i can't see it, is it tucked away somewhere ????
    And that big lump lives in the lower beam that the lower dog bone thing is connected too, It weighs about a Kilo.
  5. Yes mate a little, jack the car up on the passenger side lob a axel stand under it, blah blah!
    The is a beam about 4-5 inch wide that runs the width of the car, the will be a hole in it to get to one of the bolts for the mount, you can just see it in this picture [​IMG]
    Think it's 21mm and the other is just to the rear of this one, think this is 19mm.
    Undo these two bolts and pull them out, then back off the two I'm pointing at and it should pull out.
    Are these the ones you have left at the bottom of the picture? [​IMG]
    They push into the lower mount like this [​IMG]
  6. Oh you can't get inserts for the upper dog bone, it's a new part I'm afraid about 20 quid iirc?
  7. ianplymouth
    Yes that's the ones, i have the car quite close to the wall on the passengers side probs why i didn't see it, Cheers that, a job for Sunday as it's supposed to be pissing down.
  8. Yeah it's over to the passenger side so gives you a bit more room to get to it, I really struggled getting the 21mm bolt out as it was seized in but don't think anybody else has tbh.
    Any problems mate give us a shout!
  9. ianplymouth
    Cheers Boardy :cool:
  10. I'm doing my lower dogbone mount today Ian. If you want a hand tomorrow let me know!
  11. ianplymouth
    If you want to come down for a cuppa feel free, i will be at my workshop, been moving stuff around today so i can get the car in so i can get to both sides, might have a go at the suspension bushes tomorrow.
  12. ianplymouth
    I pulled out the lower engine mount today and this is what came out, has someone fitted the wrong one or is this right, can i fit the other type that will take the inserts i bought.
    whatever i think i need to change it as it is a bit soft :smiley:
  13. That looks like an upper one to me?
  14. What reg is your car mate?
    Do you have a late R26?
    I think that this is the later cast version so your inserts will not fit.
    The was a bit of confusion over this as Grey posted the wrong part numbers in the group buy thread.
    I'm sure the earlier rubber coated version will fit, I can measure my mount to the centres if you want mate to make sure it's right.
  15. ianplymouth
    it's a 2004 225.
  16. Last edited: Jul 27, 2015
  17. ianplymouth
    Will do Boardy, i should be going down again tomorrow.
    I will get like that, it looks a bit more substantial than the one i took out.
  18. Just asking for a picture of the bolts because I think it looks like the wrong bolts could have been fitted?
    Only because you can see thread marks within the bush, the bolts should be smooth where it passes through the bush but you can see thread marks on the inside where it looks like it's been rubbing.
  19. ianplymouth
    Yes i did notice that as well, i though that someone might not have tightened then up properly in the past. I think from memory they are threaded about half way.
  20. Yeah that's what they should be like, very strange?
  21. ianplymouth
    is it worth me fitting anything else instead, most of the time it will be tracked or driven to a track, just thought that if i am replacing, would it be better to fit a R26 one or a R26.r one ????
  22. matt e
  23. Ah nice one this is cheaper too!
    This is the same as the R26 one mate.
  24. ianplymouth
    Cheers guys
  25. Hmm have the same prob i ordered lower mount from reno and inserts from ebay not sure if i should return mount or inserts
  26. Should i order mount above or fit reno 1 sure my mount looks more like the ones in links above
  27. matt e
  28. The mount is the later cast version and the inserts are for the earlier rubber covered mount.
    I don't think you can get inserts for the cast mount you need to buy the whole new bush for the later version.
  29. Yeh and that insert is alot dearer i have the rubber covered version in but it needs swapping
  30. Probably work out cheaper to send the mount back and get the early version from eBay, the is a link above for 21 quid I think?
  31. The cheaper £21 one deffo fits? looks abit different to 1 i seen £27
  32. I'm sure that's the right one mate, and Matt knows his stuff!
  33. matt e
  34. Ordered cheers fellas
  35. Any advice on how to get the top stabiliser mount out the one that bolts to the bulk head? Cheers
