R26 engine light and interior light coming on intermitantly
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by jimboy2, Sep 14, 2013.
  1. just had a strange fault.
    gave it a little bit of stick and then broke hard and interior light flicked on. thought nothing of it, about two mins later broke not so hard interior light flicked on again and also the engine management light came on and went straight off.
    all i have done recently is the air box mod. to be honest im not 100% sure it went back in correctly so gonna strip it out tomorrow and check.
    anything else it could be? anyone had something similar, could do without any other problems!
  2. Check that the battery connections are properly secured. Might just be a loose connection down that way..
  3. that would be nice.
    would that cause a management light to come on tho?
  4. Dunno, but if you have had the battery out it is worth checking. The ecu is located between the battery and air box, so check those connections too.
  5. Took everything out again earlier. Re-fitted it all and found a loose nut on the negative on battery. Took it out for a hoon and nothing happened again so hopefully that's the end of it.
    Thankyou!
  6. Lol, dodgy earths can cause all manner of weird problems! Glad you fixed it :smile:
