R26 Engine cover mount
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by CarB8sy, Sep 13, 2015.
  1. Has anyone got 2 of the rubber gromit mounts for the engine cover and 1 ball joint that the engine cover goes on as I'm missing these parts and the engine cover is rattling slightly.
  2. You can get them from renault parts direct if nobody has them!
  3. Thanks, I'll see if anyone has them on here and if not then I will go through renault parts.
  4. Just leave the cover off, what I've done anyway :smile:
  5. Thanks I ordered and relieved to see the link you put is what I bought! For the ball joint it's the joint that the engine cover mount clips down on, not sure if they differ between the four of them, the one I'm missing is the top right. As you look over the engine from the front.
  6. Just wanted to bump this one to see if anyone now has this part. It's the tiny ball joint that the engine cover rubber mount goes on. As you are looking down on the engine from the front I'm missing the top right.
