Engine blew up.
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by James, May 7, 2016.
  1. Wasn't going very fast only about 40mph in 4th gear, accelerated a little to come off the dual carriage way up a slight hill and boom, lots of rattles from under the car.
    Opened up the bonnet and saw oil and bits of internals everywhere...
    Couldn't of just bent a rod could it, had to wreck the block with it.
    And a bit of something also decided to smash a hole in the radiator. so i decided to get a bigger aluminium one.
    But on a plus side i fetched this complete 265 engine today so will have a few parts spare plus including the turbo as i already have one.
    Bit of a squeeze but it fits in a boot of a 1 series quite nice.
    Just deciding now what i want to do with the fuelling and if to hybrid the old 225 turbo and sell both 250/265 turbos.
    F1 2.0RS likes this.
  2. Daz
    What a bumder, it was going so well!
    Sell them both cheap, one of them to me!
    James likes this.
  3. What power was it running
  4. MBC
    MBC
    Nice hole though! All good things will come out of something bad mate! Time for a build project!
  5. Another one bites the dust! Was it over the magic 300lb?
  6. Sorry to hear man :-/. Could you please tell us some more information about the engine? Age, mileage, what power & torque?
    papps likes this.
  7. It was the magic 300Ib/ft. And 295 bhp.
    Car was mapped last year by Paul at rstuning. 1.1 bar dropping to 1 bar on a 250 turbo.
    Car has driven faultlessly until now.
    225 Trophy with 95k.
    Soon to be a 325 Trophy with 41k.
    F1 2.0RS and Daz like this.
  8. sorry to hear this mate.
    Standard unmapped engines do go bang as well
  9. pot luck if their driven hard
    papps likes this.
  10. These things happen.
    I knew it was pushing it on a standard engine.
    At least it should be a bit more reliable with the 265 engine.
  11. Scary seeing this I will be at around 285/300 soon and this would be a nightmare.
    Does a 250 engine fit easily into the 225?
  12. get it forged if it goes pop
  13. Following this, engine swap might work out cheaper then forging it
  14. Yep, needs a new block.
  15. R26
    R26
    These engines shit themselves far too easy.
  16. I meant that it might be cheaper to swap for the 250 engine, then forge the 225/230 one, have no idea how much a 250 engine is
  17. Got a dilemma and hoping someone will know.
    Can I swap the dephaser and for a normal cam wheel from my old engine?
    Not going to be using vvt so it's just something to break later.
  18. No you can't but afaik the dephaser is normally retarded so won't make a difference for running
  19. That's the thing Steve, it very rarely got driven hard.
    The wife drives it 90% of the time and she drives off boost nearly all the time.
    It gets the odd bit of boost when I drive it but it's not driven hard as I usually have my kids with me.
  20. I too am interested to know if this is a realistic idea? Let me know if you find anything out?
  21. 250 engine will be about 2500 IF you find one
  22. matt e
    If you did use the 225 cam wheel, You would have to use the 225 inlet cam as well , cause the dephaser is oil driven though the cam
  23. I've just left it as it is and fitted the new cambelt and water pump.
  24. Daz
    What actually makes the mk3 engines stronger?
  25. R26
    R26
    Apparently stronger internals, I'm still waiting for pictures of these mysterious forged rods.
  26. -Jamie-
    Apparently? Going by the fact that they can take 380+lbs ft I think it's safe to say the internals are stronger.
    Ill get some photos up of them once I strip down my fucked engine for you.
  27. R26
    R26
    Pictures are pretty rare, the only I've ever found were in a build thread for a Mk3. Only looks to me that in this case the pistons are stronger.
    http://turborenault.co.uk/t16368/
  28. R26
    R26
    225 vs 172 rods.
    I'll look forward to seeing what's in your car, maybe this is a case of Renault raiding the parts bin again.
    When are you starting the rebuild?
  29. NJH
    NJH
    I was chatting to my local specialist about this subject as he also has a customer who was running 300 lb/ft and has blown the engine, OTOH he has customers that have run up to around 275 for years without any problems. The thing is if one applied a decent safety margin (for track) such as 20% back from 300 you get back to more or less stock figures which is hugely disappointing to be quite frank. Its funny that we live on a forum where there is lots of interest in tuning but honestly the Mk2 Megane looks to be the worst engine base to start from for tuning of any modern turbo engine I have come across, just as well the R26/R26.R are such fantastic cars out of the box.
    martin1977 likes this.
  30. R26
    R26
    So the Mythical Forged rods are just that?
  31. Mine ran 355ftlb & over 300bhp for over 2 years, track days too & never missed a beat.
    Lee
  32. R26
    R26
    Are you Irish?
  33. This is exact what happened to my engine. Now have a fully forged lump [emoji106]
    R26 likes this.
  34. matt e
    @James what radiator is that? A Chinese one?
  35. This is the number one reason megane engines explode when people say "I was only going slow and it exploded".
    I pilot error mixed with bad luck makes these incidents happen sooner rather than later. In future don't stick your car in 6th doing 30mph and floor it :-).
