225 Engine Bay?
Discussion in 'Detailing' started by stupertsf1, Jun 16, 2015.
  1. Hi
    My 225 engine bay has never seen any cleaner, I'm hoping to give it a going over.
    Being French, what bits would you folks recommend I avoid getting water on? I'm probably going to use Bilt Hamber Surfex HD as a cleaning solution and a gentle spray to wash off.
    Also, can the front slam panel (black metal under all the plastic) be removed? Mine looks a little ropey, I was thinking I could get it powder coated when I have my wheels done?
  2. I'd avoid getting water on all of it lol. Being French and all.
  3. MBC
    MBC
    Haha.
  4. Yeah the slam panel is just two bolts 13/16mm (cant quite remember) 4 torx screws, the 2 plastic radiator clip things, and 2 8mm bolts on the headlights.
    After thats all off, you'l have to disconnect the wiring loom clipped into it and the attached bonnet sensor/ bonnet clip mechanism.
    If you were getting it powder coated you'd have to remove the horn / sensors and other plastic bits too, i've not done that so cant really advise any more
