R26 Electrical problem?
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by SebSwainR26, May 1, 2015.
  1. Hi all,
    Just after some help/advice on what I believe is some electrical fault.....
    Got in my car earlier and went to switch the air con on and noticed the display was completely blank, the fans/blowers weren't blowing any air, the windscreen de-mister buttons weren't working etc - Nothing would work.
    On the way back I went to clean my windscreen and the jets wouldn't spray any fluid out and the wipers wouldn't start to wipe. Although if I knocked the stalk down on it's own, the wipers would wipe.
    Also the radio wouldn't switch off when I took the card out of the slot and locked the car, I had to manually press the on/off button.....
    I switched my lights on when I got home and they worked fine, there were no lights etc on the dash, indicators were ok.
    Where should I start? Could it be fuse related?
    Any helps much appreciated, cheers.
  2. To start with i'd be looking for a dodgy earth connected to the dash
