R26 Electrical Problem
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by TimR26, Dec 13, 2014.
  1. TimR26
    I'm having electrical problems with my R26.
    It's causing the doors to constantly lock/unlock, rev counter and speedo not to work, radiator fan to constantly run on high speed etc
    Dash is showing Braking Fault, Steering Fault warning, and Check ESP. The engine won't turn off so I'm having to stall it and once engine is off the lights and radiator fan continue to run until I disconnect the battery.
    Any ideas on how to fix the problem?
    Renault replaced the UPC fuse computer yesterday and it had fixed the problem until I washed my car this afternoon.
  2. Sounds like a possible water ingress problem
