Having an issue with a couple of warning lights on the dash. Firstly, last week I had the 'check airbag' light come on but went off straight away. As I've fitted buckets I just thought one of my dodgy soldering connections had failed so had a good look around but all looked fine and the light went off so I left it. It was fine for a couple of days then flashed on again as well as the 'check abs' light but both went off again. After the car being stood all weekend the 'check airbag' light has come on and stayed on. The 'check abs' flashed up once but never came back. I added new resistors one at a time and tested each but it hasn't gone off. Any ideas? Cheers
