I tried searching but to no avail. My 225 says this on the dashboard, has anyone else had this and is it a common thing or could it be a million different things?
Mine says this before then maybe a day or two later same again and the car completely shut down, turned out that water had got into the fuse box and basically messed with everything, this was on my 54 ph1 Paul
It has said it since I bought the car 6-7months ago. Everything seems to work so I'm a bit confused. What's a rotary switch?
